• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    How would I create threads like this
    146 Views, 5 Replies
    01-06-2013 05:07 AM
    I'm trying to learn to use autodesk inventor pro student version by redoing stuff I've been able to find. Currently I'm trying to learn how to create this kind of thread thingy. Any ideas how to start? (this was parasolid cad file originally which I converted)
    I've been trying to go around this several ways but can't seem to be able to do it.
    Niko
    Please use plain text.
    Distinguished Contributor
    Mason-Paul
    Re: How would I create threads like this
    01-06-2013 06:38 AM in reply to: niko.jarvinen
    First it would be helpful if we knew waht version of inventor you are using.
    SO I am asuning you actually want to "cut" this thread.
    OK see the 2 attached ipt files on is internal one is external thread, this is a imperial square cut thread but it will give you some idear of how to do this, just open it as normal and have alook.
    I'll also post the IDW files for you in another mesage
    Thanks in advance for any help & advice
    Inventor 2012 Pro
    Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
    Mason-Paul
    01-06-2013 06:39 AM in reply to: Mason-Paul
    And here are the idw files
    Inventor 2012 Pro
    Active Member
    01-06-2013 07:13 AM in reply to: Mason-Paul
    Thanks! Didn't even think of using coil + circular pattern. Works like a charm! Thanks for pointing to the right direction.
    -Niko
    *Expert Elite*
    blair
    01-06-2013 08:54 AM in reply to: niko.jarvinen
    If it's a single part and the threads are a standard part (listed in the Thread.xls file) and you are on IV2013, install the Thread App and use it to "cut" the threads.
    It's the automated way of doing threads on a part, but using the coil-cut method (as posted) teaches you how to do.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
    Active Member
    01-06-2013 09:10 AM in reply to: blair
    Thanks but in this case it's far from standard so I'll need to use the coil-cut method.
    Niko
