• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    How to use sweep commantd in sheet metail.
    121 Views, 1 Replies
    02-19-2013 03:54 AM
    I have make component in sheet metal with sweep command and then i have to make its flat patten.
    But there in no sweep command in sheet metal.i have to go to in modeling agian.
    Pls help.
    Dattatray Indalkar.
    With Warm Regards,
    Datta Indalkar.
    Please use plain text.
    Distinguished Contributor
    Mason-Paul
    Re: How to use sweep commantd in sheet metail.
    02-19-2013 06:51 AM in reply to: indalkar.dattatray
    That will be because complex shapes in Inventor, as in the real world, can not be flat patterned ie Radius Elbow Bends ,"U" and "S" Bend pipes and tubes. These are usually, bent on a pipe/tube bending machine form a straight length of pipe or tube, or  alternately made up of several  welded up segments that are rolled from flat.
    Best way is probably to draw a segment, build your shape as an assembly, show the flattened & dimensioned segment in one sheet of an IDW and the Finished shape (assembly)with dimentions in another sheet.
    I don't do much sheet/plate steel wok of this type but this is usually the way I do it.
    Thanks in advance for any help & advice
    Inventor 2012 Pro
    Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
