• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: How to use iLogic Rule to delete rules and features in other parts?
    08-22-2012 09:22 AM in reply to: jdkriek
    Hi
    I just made some changes in there as i needed and its working but one more thing i waana do is delete all parameters
    either user parameters or model
    Auto = iLogicVb.Automation
    Dim iLogicAuto As Object
    iLogicAuto = Auto
    Dim oDoc As Document
    oDoc = ThisApplication.ActiveDocument
    'Master file name
    If Not (ThisDoc.FileName) = "iLogic" Then
        Dim ruleName As String
        Dim rules As Object
        rules = iLogicAuto.rules(oDoc)
            'Remove rules
            If Not (rules Is Nothing) Then
                For Each rule In rules
                    ruleName = rule.Name
                    iLogicAuto.DeleteRule(oDoc, ruleName)
                Next
                Else
                i = MessageBox.Show("No Rules are in File")
            End If
        Dim oFeatures As PartFeatures
        oFeatures = oDoc.ComponentDefinition.Features
        Dim oFeature As PartFeature
            'Remove suppressed features
            For Each oFeature In oFeatures
                featureName = oFeature.Name
                i = MessageBox.Show("Click Yes to delete all Fetures or No to Suppressed or Cancel to abort", "My iLogic Dialog", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
    '                If Not Feature.IsActive(featureName) Then
                    If i=vbYes Then
                    i = MessageBox.Show("Deleting All Features ")
                        oFeature.Delete
                    Else If i=vbNo Then
    '                i = MessageBox.Show("Deleting Supressed Features ")
                    oFeature.Delete
                    End If
                Else
                    i = MessageBox.Show("Action canceled ")
                    End If
            Next
    End If
    'but now something i wanna do is
    'Remove all  Parameters too
         If Not (param Is Nothing) Then
             For Each param In params
              i = MessageBox.Show("Checking for Parameter in File")
            i = MessageBox.Show("No.of Parameters exists are ="& param.count)
             paramname=param.Name
             On Error Resume Next
             param.delete(oDoc, paramName)
                   paramName =ThisDoc.Document.ComponentDefinition.Parameters
                iLogicAuto.Deleteparam(oDoc, paramName)
             Next
            Else
               i = MessageBox.Show("No Parameter are in File")
    'Please help me in the I will be greatful
    'Thanks and regards
    "vicky
    Please use plain text.
    08-22-2012 09:41 AM in reply to: jdkriek
    hi dear sir/Buddy.................
    A solution u did give earlier to some helped me alot what i wanna achive , Imade some chages according my need
    and its working but i wanna little more help from u please......
    iLogicAuto = Auto
    'Master file name
        Dim rules As Object
            'Remove rules
                Next
                Else
            End If
                    If i=vbYes Then
                        oFeature.Delete
                    Else If i=vbNo Then
                    oFeature.Delete
                    End If
                Else
                    End If
            Next
    End If
    'but now something more i wanna do is...... delete parameters
                Next
                Else
            End If
     'Regards
     'vicky
    Valued Contributor
    zdhrichard
    08-22-2012 11:20 AM in reply to: hunkvicky.87
    Removing all  Parameters is what I wanna too.
    Thanks lot for your contribution, Vicky.
    I tested your code, but I do not know what is happened, code cannot get into "For .... Next" Loop.
    That means:    "If Not (param Is Nothing) Then" gives me "False" although I have lot of parameters in my model. I could use "Delete All Rules and iLogic Parameters" to delete them. But the codes which you provided does not work.
    Maybe it is because I am using Inventor 2009 if it is working in your side.
    Any does anybody know how to delete suppressed components in *.iam by iLogic code?
    Thank, anyhow.
    Richard Z.
    Autodesk Inventor Professional 2013 (64 Bit) SP1.1
    Windows 7 Professional Service Pack 1
    Intel(R) Xeon(R) CPU E5645
    12.0 GB Memory
