Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How to position, precisely, the key with the Key Generator?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I use the Key Generator from the Design Accelerator and drag the red arrow to position the key under the gear.
Numbers change, and when i position the key they disappear.
There is no way to input a precise dimension. am i right?
Re: How to position, precisely, the key with the Key Generator?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The only way I have seen to position it precisly is to dig into the part the Keyway was created in and Explode the Accelerator feature so you can modify the iFeature by itself. The problem with this is that once you do this the Edit Keyway in the Assembly becomes broken. Still not a bad way to get the features down to the part tree.
IMAGINiT's Manufacturing Solutions Blog:
http://blogs.rand.com/manufacturing/
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Where is the command to explode the Keyway?
I right clicked the Key Connection, didn't find
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Find the key in the model browser, click on its flush constraint, and change its value. Is that what you're trying to do?
Also, if you're tying to rotate the keyway, you can accomplish this at the part level with the "Move Face" command, set to "Free Move." Then select "Reposition Triad," move it to a point at the center of rotation, and you can rotate the keyway to a precise angle. This method still allows you to edit the keyway from the design accelerator, too.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Silly me, overthinking the obvious on that one.
Yes, just expand the Key Connection in the browser and adjust the constraint values, the iFeatures in the parts will follow suit.
