Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How to model an Oloid
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
I am new to inventor. Can anybody show me how to model an oloid in inventor?
I can't get it to work using the revolve tool. I found the attachment in a previous post but
the post didn't really explain how he did it. Thanks.
Re: How to model an Oloid
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try attaching again-- WinZip claims it's not a valid archive.
If what you've posted is a .ipt model of an oloid, then you should be able to see how the creator modeled it by examining sketches and features.
The attached file is my (version 2013-- you didn't mention what version you're working in) attempt. I don't know if it's mathematically correct, though.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't think anyone came up with a true solution back then
http://forums.autodesk.com/t5/Autodesk-Inventor/Ol
it might be interesting to give it a try again.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
I'm working in inventor 2013. I shall try to reattach the oloid version from the above mentioned thread.
It would be interesting to see if inventor can make a sheet metal pattern.
I've tried to use the shell function but I haven't been able to get it to work.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
Sam B your oloid was a good attempt but comparing with oloid images from the net
I've noticed the ridge doesnt seem to go the whole length of the side meaning the
edge is just 240degree arcs on each end and the rest is transistion if that makes
any sense.
Comparing to the solution from the other thread the end is also square (in profile)
on that one which I think is probably correct.
Anyhow good effort you made it a lot further then I could. By the way a good
documentary on oloids on youtube is "the old man and the oloid'.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I took a crack at it and came close. There is a visible flaw/artifact. I'm not sure how to improve the loft; probably with more rails. I modeled a quarter of the shape and mirrored the rest. See what you can do with it. I'm out of time.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi JD,
I have had a few attempts at the Oloide and have something nearly right.
If you play with the dimension "Adjust sketch (1mm to 74.95)" sketch found within the Loft
called "Adjust this Loft" I can get some fairly interesting results (not perfect Class A but Ok).
Any feedback would be welcome.
Cheers
Mark
Inventor Professional 2013
Build 176 SP1.1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
I shall attach a mathematical paper on the Development of the Oloid.
I think figure 4 may be what a flat sheet metal pattern may look like.
Thanks.
