• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Zenjashi
    How to make the cut in a drill bit?
    1007 Views, 4 Replies
    03-25-2011 06:02 AM
    Hello Everyone,
    I am drawing an adjustable drill stop. I have basically chamfered a cylinder to create a point. I know what the sweep profile looks like, I just cannot seem to angle the plane to be tangent with the chamfer. Any suggestions?
    -Max
    IV2011 Professional 32-Bit
    Please use plain text.
    *Expert Elite*
    Re: How to make the cut in a drill bit?
    03-25-2011 06:09 AM in reply to: Zenjashi
    You title says cut a drill bit.
    Description says a adjustable drill stop.
    Can you provide pictures of similar real part?
    I'm not sure what you are after.
    Can you attach the ipt file here?
    Did you get this problem sorted out http://forums.autodesk.com/t5/Autodesk-Inventor/Disobediance/m-p/2953006
    *Expert Elite*
    Curtis_Waguespack
    03-25-2011 06:37 AM in reply to: Zenjashi
    Hi Zenjashi,
    You can find an example of a drill bit profile in the practice drawing PDF on sheet 11 at this link:
    http://inventortrenches.blogspot.com/2011/03/modeling-practice-drawings-for-inventor.html
    You'll create the profile on the end of the shaft, and then use the Coil tool to cut the profile at the desired pitch and length. Then you can use the Circular Pattern tool and pattern the cut 2 times to complete the other side. You'll want to place the chamfer on the end after making the coil cuts.
    If I have a chance I'll post an example later.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    *Expert Elite*
    Curtis_Waguespack
    03-25-2011 06:49 AM in reply to: Curtis_Waguespack
    Hi Zenjashi,
    Here is the part file to use as an example.
    I hope it helps,
    Curtis
    Active Contributor
    05-06-2012 10:08 AM in reply to: Curtis_Waguespack
