• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    xboxphili
    How to make my skeletal model for my steel frames visible in the DWG enviornment
    196 Views, 5 Replies
    10-04-2012 07:20 AM
    I've generated my steel frame model using a skeletal model technique. So my part file consists of only sketch lines representing where I want my steel to be placed. I've created an assembly and used that in my inventor.dwg file. The problem is that I need to dimension to the sketch file and not to the model shapes because the sketch lines define the center of gravity. These lines aren't visible even though I've right-clicked on the content and selected "Get Model Sketches". Does anyone know how I can get my sketletal model through to the DWG enviornment?
    Please use plain text.
    *Expert Elite*
    Re: How to make my skeletal model for my steel frames visible in the DWG enviorn
    10-04-2012 07:29 AM in reply to: xboxphili
    Did you set to Include?
    http://forums.autodesk.com/t5/Autodesk-Inventor/retrieve-a-bend-from-sweep/td-p/3646098
    Active Member
    xboxphili
    10-04-2012 07:41 AM in reply to: JDMather
    Does having sketches turned on in the original part file affect visibility later on, say for instance in my .dwg file?  I just turned them on, saved and retrieved the lines by selecting "Get Model Sketches". So I have what I need but I just wanted to verify. Thank you for your quick response.
    *Expert Elite*
    10-04-2012 07:47 AM in reply to: xboxphili
    I don't think you have to have them visible in the part files, but try some experiments.
    Also, I didn't check what release you are using.
    Active Member
    xboxphili
    10-04-2012 08:16 AM in reply to: JDMather
    I'm running the 2013 demo and I'm producing content for a softare evaluation. Do you think Solidworks would provide any advantages for steel structures? I've completed a similar software demo/evaluation for Revit Structures as well because I have experience with both platforms but I previsously only used Inventor only for structural ductwork. Personally I am most comfortable in an Autodesk envoirnment. Not that Revit feel like an Autodesk product...
    *Expert Elite*
    10-04-2012 09:03 AM in reply to: xboxphili
    SolidWorks does this as multi-body solids that you push out.
    In the end I see no significant differences.
