• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    How to make attached part Adaptive?
    109 Views, 1 Replies
    12-01-2012 07:28 AM
    When I create part .ipt directly in assembly .iam, I can make it adaptive. I'm doing the projection of geometry. Detail goes adaptive. Geometry appears as a link.
    But if I put in the assembly finished parts or remove part created in the assembly, and then insert it back, the adaptability of parts did not get to create. Then the projection geometry inserts usual nonadaptive geometry without reference.
    Can I make a finished part adaptive, without creating a component at the place in this assembly?
    Thank you!
    Please use plain text.
    Valued Mentor
    Re: How to make attached part Adaptive?
    12-01-2012 05:39 PM in reply to: bodich
    Try to open a part and un-check Adaptively Used in Assembly box in Document Settings-->Modeling.
    Please see the attached picture for clarity.
    Igor.
    Web: www.meqc.com.au
