• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    WillieArolf
    How to flatten an elbow like a sheet metal development
    446 Views, 9 Replies
    10-30-2012 01:49 AM
    I have an elbow with a slit on the other side and would like to use Flatten feature in sheet metal. How do I do it? I tried but an error pops-up, and I do not have an idea does it mean.
    I have attach the file.
    Maybe, anybody has a workaround if Inventor can not make it. Appreciate your assistance.
    Thanks & Regards,
    Willie
    Please use plain text.
    Valued Mentor
    mpatchus
    Re: How to flatten an elbow like a sheet metal development
    10-30-2012 04:05 AM in reply to: WillieArolf
    See attached part.
    Creating the sheet metal part using the available tools will usually result in a decent flat pattern.
    Sometimes it hit or miss, at least in my experience.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    10-30-2012 05:34 AM in reply to: WillieArolf
    How will the part be manufactured?
    Can you post a picture of an actual finished part?
    Distinguished Contributor wh
    wh
    Betreff: How to flatten an elbow like a sheet metal development
    10-30-2012 11:53 AM in reply to: WillieArolf
    This is a pretty good example, that people shouldn't trust very much in Inventor's Flat patterns, that are made from contour roll.
    Walter
    Valued Contributor
    WillieArolf
    10-30-2012 05:09 PM in reply to: mpatchus
    Hi Mike,
    Thank you for the assistance.
    Is that the correct shape "Rectangle" after invoking the Flatten feature?
    I thought there should be a slope kinda shape.
    Thanks & Regards,
    Willie
    Valued Contributor
    WillieArolf
    10-30-2012 05:16 PM in reply to: JDMather
    Hi JD,
    The part is made of a flexible jacket (I think you have already encountered this issue before)... I am just looking for an alternative way in making use of Inventors ability in creating flat patterned using the sheet metal development.
    Honestly, I am trying my best to convience my boss that we should stick in Inventor rather than shifting to solidworks. For the reasons that I am ever since a user of Autodesk products and pretty much used to its features and commands.
    But, when it comes to flatting an elbow like shape, I do not know how to defend it.
    That is why, I am trying my best to look for any alternative solutions by of course using Inventors ability.
    Thanks & Regards,
    Willie
    10-31-2012 04:48 AM in reply to: WillieArolf
    WillieArolf wrote:
    Honestly, I am trying my best to convience my boss tha....
    Have your boss invite a VAR to demonstrate this same part in SolidWorks.   :smileylol:
    10-31-2012 10:27 AM in reply to: WillieArolf
    Buy this program - cheap and they did have it free for 2011.  Not a salesman - just a user.  Download a trial and take a look.
    http://www.ductpro.net/
    Valued Contributor
    WillieArolf
    10-31-2012 05:06 PM in reply to: JDMather
    Hi JD,
    One of my collegue who is so eager to acquire solidworks (well, for the reason that he does not know how to use Autodesk Inventor) did brought my boss to one of the talks in solidworks and they have indeed should him that solidworks can do the sheet metal development after they flatten an object.
    But, I did told my boss that they may have used a plug-in or third party software to the job. That is why I am asking for an alternative solutions like a plug-in for Inventor to the job.
    Thanks & Regards,
    Willie
    Valued Contributor
    WillieArolf
    10-31-2012 05:12 PM in reply to: RobJV
    Hi RobJV,
    Thank you for sharing this, I will try to DL the trial and look onto it.
    Thanks & Regards,
    Willie
