• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    trumpy81
    How to fillet this part?
    225 Views, 2 Replies
    01-18-2013 05:58 AM
    GDay All,
    I have a part that I want to fillet but only the edges that are highlighted. Please see the attached photo.
    I have tried using sweep but it insists on returning similar results to the fillet command in that it wants to fillet the entire edge which is not what I want.
    Anyone have a simple solution?
    Regards
    Andy M
    Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
    Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
    1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
    Please use plain text.
    Valued Contributor
    Re: How to fillet this part?
    01-18-2013 06:38 AM in reply to: trumpy81
    Andy, with sweep it's posible but make sure that you select the sweep and not the edge.
    An other option is to use the fillet command and use 'Variable radius', place points were you want to start the fillet and change the Radius to zero. See attachment for an example.
    Rob.
    Autodesk Inventor 2012 Certified Associate & Autodesk Inventor 2012 Certified Professional.
    Software in use: Inventor 2013, SolidWorks 2011
    Also experience with: Solid Edge untill ST4,
    trumpy81
    01-18-2013 07:34 AM in reply to: VdVeek
    Thanks Rob. I now see where I was going wrong when using sweep.
    I have to chalk it up to another 'grey' moment ... lol
    Regards
    Andy M
