Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How to disable reflection s and gradients in shaded views
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You would like to have an option to disable reflections in the shaded views that you create.
Answer
We introduced from Inventor 2010 support for disabling reflections in drawings. In order to do this, users need to add DWORD registry key named "Suppress Specular Color" with value greater than zero under the following registry key.
Note:
Prior to creating this registry key, you need to have the following hotfix installed for Inventor 2010:
http://usa.autodesk.com/getdoc/id=DL15338178
For Inventor 2011, you need to have SP1 installed.
Open the system registry and locate the following registry keys listed below (Start > Run > RegEdit):
1. Inventor 2010
[HKEY_CURRENT_USER\Software\Autodesk\Inventor\Regi
Create a key with this value:
"Suppress Specular Color"=dword:00000001
2. Inventor 2011
If the key is not present or its value is zero or less, then reflections are enabled under drawings (Default behavior).
Note: The key is read only once per Inventor session - after adding the key or changing its value, users need to restart the Inventor session.
Please find attached as well the registry files for both Inventor versions. By double clicking the appropriate registry file, you can automatically create in your registry the key, as explained above.
Daniela Koloszko
Product Support Specialist
Autodesk Product Support
MFG
Re: How to disable reflection s and gradients in shaded views
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
EXCELLENT!!!!!!!
Works perfect on 2011 Sp1...
Just in time too. I'm about to create hundreds of shaded IDW files for all our new products. I hated the reflections.
Thank you Autodesk. (and Daniela)
2012 Product Design Suite Ultimate
Windows 7 64 bit
90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
Re : How to disable reflection s and gradients in shaded views
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
And for the 2012 versions ?
Regards
Dom
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The solution for Inventor 2012 is the same:
Daniela Koloszko
MFG
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Daniela,
I'm happy to read you.
But I have tried this registry key, but there is no effect.
Regards
Dom
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Just a screenshot. I have made test on inventor 2011 SP1 and the result is the same with Inventot 2012 SP1.
Dom
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I did a test in Inventor 2012 SP1 and it works. Please see attached images and also the registry fix which I have added for your convenience. You just need to double click it in your machine and the registry key will be automatically created for version 2012.
Daniela Koloszko
MFG
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Maybe is another problem. I send you my part and drawing.
For information I have a French version.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've tried this several times with no luck on 2012. I've attached a screen shot of my registry files.
Brian
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you attach an example, a part and drawing with reflection?
Daniela Koloszko
MFG
