• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    zdhrichard
    Accepted Solution
    How to delete suppressed components by iLogic Rule
    250 Views, 16 Replies
    01-24-2013 06:21 AM
    I have an assembly which includes lot of parts (*.ipt) or sub-assembly (*.iam).
    I have some ilogic rules to control to suppress or unsuppress them.
    Now for the released assembly, I want delete all suppressed components by ilogic rule.
    Could anybody help me the ilogic code to get this function?
    Richard Z.
    Autodesk Inventor Professional 2013 (64 Bit) SP1.1
    Windows 7 Professional Service Pack 1
    Intel(R) Xeon(R) CPU E5645
    12.0 GB Memory
    Please use plain text.
    *Expert Elite*
    mrattray
    Re: How to delete suppressed components by iLogic Rule
    01-24-2013 07:26 AM in reply to: zdhrichard
    Dim oComp As ComponentOccurrence
    Dim oComps As ComponentOccurrences
    oComps = ThisDoc.Document.ComponentDefinition.Occurrences
    For Each oComp In oComps
    	If Component.IsActive(oComp.Name) = False Then oComp.Delete
    Next
    Mike (not Matt) Rattray
    Valued Contributor
    01-24-2013 07:44 AM in reply to: mrattray
    Hi Mike, by any chance do you know how to do the same but for deleting suppressed features in the part environment?
    Wayne Helley
    Inventor 2013 Certified Professional
    Autodesk Inventor Professional 2011
    Windows 7 Enterprise, 64-bit
    *Expert Elite*
    mrattray
    01-24-2013 07:58 AM in reply to: waynehelley
    Dim oFeature As PartFeature
    Dim oFeatures As PartFeatures
    oFeatures = ThisDoc.Document.ComponentDefinition.Features
    For Each oFeature In oFeatures
    	If Feature.IsActive(oFeature.Name) = False Then oFeature.Delete
    Next
    Valued Contributor
    zdhrichard
    01-24-2013 10:48 AM in reply to: mrattray
    Thanks lot, Mike.
    Richard Z.
    12.0 GB Memory
    Valued Contributor
    zdhrichard
    01-24-2013 10:54 AM in reply to: mrattray
    Hello MIke,
    For deleting features, do you know how to delete the relative sketches?
    I tested the codes, it could delete features, but the sketches are still in the tree.
    Richard Z.
    12.0 GB Memory
    *Expert Elite*
    mrattray
    01-24-2013 11:00 AM in reply to: zdhrichard
    When I tested it the code deleted the consumed sketches as well as the feature. Can you attach the model?
    Valued Contributor
    zdhrichard
    01-24-2013 11:23 AM in reply to: mrattray
    Here is a simplified model.
    Richard Z.
    12.0 GB Memory
    *Expert Elite*
    mrattray
    01-24-2013 11:31 AM in reply to: zdhrichard
    Did you already run your delete features sub on this part? The code doesn't do anything at all for me.
    Valued Contributor
    zdhrichard
    01-24-2013 11:43 AM in reply to: mrattray
    Yes, I did. This is the result after runing the code.
    Richard Z.
    12.0 GB Memory
