• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    How to create a Workplane from a face using SelectSet[]
    115 Views, 2 Replies
    11-08-2012 02:13 PM
    I am making a C# Add-in, I need to create a plane from a selected face, I am using the follwing code, but I am getting stuck. Can you Help me?
    if (((mApp.ActiveDocument != null)))
    if ((mApp.ActiveDocument.DocumentType == DocumentTypeEnum.kPartDocumentObject))
    PartComponentDefinition oPartCom = mApp.ActiveDocument as PartComponentDefinition;
    PartDocument oDoc = mApp.ActiveDocument as PartDocument;
    if ((oDoc.SelectSet[1]) is Face)
    System.Windows.Forms.MessageBox.Show("You just selected a surface", "Surface Evaluator");
    WorkPlane oPlane = oDoc.SelectSet[1] as WorkPlane; //HERE I SELECT THE WORKPLANE FROM THE FACE
    //HERE I USE IT TO CREATE MY REAL WORKPLANE TO USE THE SKETCH BUT THERE IS A PROBLEM
    WorkPlane oWorkPlane = oDoc.ComponentDefinition.WorkPlanes.AddByPlaneAndOffset(oPlane, 1.0);
    //THIS PART SHOULD WORK AFTERWARDS
    PlanarSketch oSketch = oDoc.ComponentDefinition.Sketches.Add(oWorkPlane, false);
    TransientGeometry oTG = mApp.TransientGeometry;
    ObjectCollection oFitPoints = mApp.TransientObjects.CreateObjectCollection();
    PartComponentDefinition oCompDef = default(PartComponentDefinition);
    oCompDef = oDoc.ComponentDefinition;
    Camera oCamera = mApp.ActiveView.Camera;
    THANK YOU GUYS!!!
    Please use plain text.
    Valued Mentor
    Re: How to create a Workplane from a face using SelectSet[]
    11-12-2012 05:23 AM in reply to: bravaiser
    You could get better reponse if you post this in the inventor customisation section.
    You mention there is a problem... when you repost, also mention what the problem is that you are encountering.
    -Mark
    Inventor 2014 Pro on Windows 7, 64bit
    (please give Kudos or Tag as Solved if your issue is resolved)
    Active Member
    11-12-2012 05:30 AM in reply to: bravaiser
    The problemis that the plane oPlane is pass as null to when I used the selection (in this case a face) oDoc.SelectSet[1] as WorkPlane.
    Thanks in advance
