Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
How to create a Macro
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hello Guys,
I am using inv2011. I have to create rec. blocks very often and in inv2011 . I have to constraint it in middle.
Can i write a Macto that gives me constraint rec block in sketch. This feature already available in Inv12.
Re: How to create a Macro
- Highlight
- Email to a Friend
You dont have the ability to write macros in Inventor 2013 but you can automate some of the design process using ilogic.
Here are some links:
http://inventortrenches.blogspot.com/search/label/
I hope this helps.
Cheers
Chris
Design Engineer
Sheffield UK
Chris Rodway
Design Engineer
Sheffield, UK
- Highlight
- Email to a Friend
chrisrodway wrote:You dont have the ability to write macros in Inventor 2013 but you can automate some of the design process using ilogic.
I don't have enough skill with them to be able to help the OP with his request, but VBA macros are still available in Inv 2013.
Inventor 2013
Windows 7 64 Bit
- Highlight
- Email to a Friend
Yea sorry I miss spoke, I ment you dont have the abilty to record macros in inventor so i thought ilogic might be the better may to go.
Chris Rodway
Design Engineer
Sheffield, UK
- Highlight
- Email to a Friend
Yes, that's true, and unfortunately that feature has never existed (would be nice though).
kalpesh_43, I did some digging around. We used to use a macro that will (I think) do what you want, but took it out of our macro files when we set up 2013 since it had a function that replaces it. Fortunately I kept an exported copy of it for reference. This is based on one I found online somewhere a while ago, then modified slightly (mostly to add error catches that didn't exist in the original). I would give credit to the originator, but don't recall who that is.
Sub InitialRectangle()
' Make sure a part document is active.
If ThisApplication.ActiveDocumentType <> kPartDocumentObject Then
MsgBox "Must have a part active", vbOKOnly, "Error"
Else
Dim oPartDoc As PartDocument 'for the active part
Dim oCompDef As PartComponentDefinition
Dim oSketch As PlanarSketch
Dim oLines(1 To 4) As SketchLine 'each of the 4 sides of the rectangle
Dim oRectLines As SketchEntitiesEnumerator
Dim count As Integer
Dim XVal As Integer
Dim YVal As Integer
Dim bFoundOrigin As Boolean
Dim oTransGeom As TransientGeometry
Dim oDiagonalLine As SketchLine 'the diagonal line in the rectangle
Dim oOriginPoint As SketchPoint
Dim oOrigin As WorkPoint
Set oPartDoc = ThisApplication.ActiveDocument
If oPartDoc.SketchActive = True Then 'check to ensure you have a sketch active
Set oCompDef = oPartDoc.ComponentDefinition ' Set a reference to the component definition.
Set oSketch = oCompDef.Sketches.Item(oCompDef.Sketches.count)
XVal = 3 'set this to half the horizontal size you want the rectangle to be IN CENTIMETERS
YVal = 2 'set this to half the vertical size you want the rectangle to be IN CENTIMETERS
bFoundOrigin = False
Set oTransGeom = ThisApplication.TransientGeometry 'Set a reference to the transient geometry object.
If oSketch.SketchPoints.count > 0 Then 'try to find if the origin has been projected already
For count = 1 To oSketch.SketchPoints.count
If oSketch.SketchPoints(count).Geometry.X = 0 And oSketch.SketchPoints(count).Geometry.Y = 0 Then
bFoundOrigin = True 'if you have found the origin, keep a ref to it
Exit For
Next
With oTransGeom 'Draw the 2-point rectangle
Set oRectLines = oSketch.SketchLines.AddAsTwoPointRectangle(.Create Point2d(-XVal, -YVal), .CreatePoint2d(XVal, YVal))
Set oDiagonalLine = oSketch.SketchLines.AddByTwoPoints(.CreatePoint2d( XVal, -YVal), .CreatePoint2d(-XVal, YVal))
oDiagonalLine.Construction = True
With oSketch.GeometricConstraints
Call .AddCoincident(oDiagonalLine.StartSketchPoint, oRectLines(1))
Call .AddCoincident(oDiagonalLine.StartSketchPoint, oRectLines(2))
Call .AddCoincident(oDiagonalLine.EndSketchPoint, oRectLines(3))
Call .AddCoincident(oDiagonalLine.EndSketchPoint, oRectLines(4))
End With
If bFoundOrigin = False Then
Set oOrigin = oCompDef.WorkPoints.Item(1)
Set oOriginPoint = oSketch.AddByProjectingEntity(oOrigin)
Call .AddMidpoint(oOriginPoint, oDiagonalLine)
End With
Else
Call .AddMidpoint(oSketch.SketchPoints(count), oDiagonalLine)
End With
End With
Else
MsgBox "There is no sketch active. Operation Terminated.", vbCritical
End Sub
Inventor 2013
Windows 7 64 Bit
- Highlight
- Email to a Friend
Hi kalpesh_43
Additionally there is this:
http://www.mcadforums.com/forums/viewtopic.php?f=3
I hope this helps.
Curtis
