• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    How to convert 3d dwg files to solid bodies
    409 Views, 6 Replies
    06-25-2012 09:06 PM
    Please anyone tell me how to convert 3d dwg files to solidbodies
    Please use plain text.
    Valued Mentor
    Rich.O.3d
    Re: How to convert 3d dwg files to solid bodies
    06-25-2012 09:58 PM in reply to: p.raviteja1992
    open the dwg in inventor
    when you have the dwg selected in the open dialogue, hit the options button and make sure you set to import
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Member
    06-25-2012 11:36 PM in reply to: Rich.O.3d
    Thank you
    but i think there is some problem with my inventor.
    I can get the preview but i can't get the body
    Please check if there some problem with my dwg file
    If possible upload the part file
    Distinguished Contributor wh
    wh
    06-26-2012 03:35 AM in reply to: p.raviteja1992
    There are no really good results, the source is only a mesh.
    I can't upload the file because of it's size (about 4 MB). Try again for yourself Open -> DWG import. Import is lasting several minutes
    Walter
    06-26-2012 04:34 AM in reply to: p.raviteja1992
    Your problem title is incorrect - as indicated by Walter there are no solids in the file.
    06-26-2012 04:38 AM in reply to: JDMather
    You might be able to open a layer at a time and separate into different parts and stitch to solids - but I think I would start over and do the model correctly (as solids rather than meshes).
    Valued Mentor
    Rich.O.3d
    06-26-2012 04:00 PM in reply to: JDMather
    hmmm polyface mesh!
    would these be prosteel objects?
    if so you need to use export to an acis file ( _PSCREATEACIS or something like that, its been a while)
    then you can bring into inventor
    CAD Management 101:
