• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    How to constain the hole 'B' with flat surface 'A'
    89 Views, 2 Replies
    10-17-2012 10:58 PM
    I want to transfer the rotation motion of part 'C' at a pivot point 'D' , to part 'E' which is pivoted at 'F', while the flat surface of the part 'c' is inserted in to hole 'B' of part E.Please give solution to give an assembly constrain to hole 'B'  with flat surface 'A'
    Please use plain text.
    *Expert Elite*
    Re: How to constain the hole 'B' with flat surface 'A'
    10-18-2012 04:40 AM in reply to: soorajkakkoth
    Contact sets
    or
    create dummy surface and Tangent Constraints
    or
    Dynamic Simulation 3D Contact Joint.
    attach your assembly here if you can't figure it out.
    Inventor Professional 2014 Edu 64-bit
    *Pro
    sbixler
    What version of Inventor are you using?  Can you post the assembly, at least with parts E & C, plus support pins?  What is the range of motion of C?  There are several ways you might accomplish this, but it depends on your requirements.  Contact Set may be all you need.
