• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Anthony
    How to check which assemblies a part file references
    150 Views, 12 Replies
    02-04-2013 05:47 AM
    I was wondering is there is a way to select an Inventor part file and see which assembly file or files that is is currently used in ? It would be extremely useful to be able to see a list of all the assembly files which are using one particular part so when modifying the part you would know which assemblies would change.
    Product Design Suite Ultimate 2013
    64-bit HP Z400, Intel Xeon W3550 3.07GHz
    12.0GB RAM, ATI FirePro V4800 (FireGL)
    Please use plain text.
    Valued Mentor
    mpatchus
    Re: How to check which assemblies a part file references
    02-04-2013 05:52 AM in reply to: Anthony
    Vault would be the best way to do that.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Anthony
    02-04-2013 05:56 AM in reply to: mpatchus
    Thank you very much for the reply, I'm sorry I forgot to mention I do not currently use Vault, I was wondering if there was a way to do this for non-Vault users ? Thanks
    Valued Mentor
    mpatchus
    02-04-2013 05:57 AM in reply to: Anthony
    I don't know of any way to do it without using Vault.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Anthony
    02-04-2013 05:59 AM in reply to: mpatchus
    OK thanks, I guess Vault is the way forward then :smileyhappy:
    Doug_DuPont
    02-04-2013 06:32 AM in reply to: Anthony
    In Design Assistant/Tools/Find/Where Used
    You can use this. Beware
    Only use this on Small Folder sturcture. If you scan a large folder sturcture it will take a week to find files.
    I don't use it, But it's there to use.
    Douglas DuPont
    Inventor 2013
    GeForce GTX 580
    Windows 7 64 Bit
    Anthony
    02-04-2013 06:38 AM in reply to: Doug_DuPont
    Thanks, could you post a screen shot of where this option is, I can't seem to find the 'where used' option is ?
    Valued Mentor
    mpatchus
    02-04-2013 06:46 AM in reply to: Anthony
    Like Doug said, be real careful where you use this, it literally could take days to run.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Anthony
    02-04-2013 06:50 AM in reply to: mpatchus
    Much appreciated. :smileyhappy:
    Anthony
    02-04-2013 07:12 AM in reply to: mpatchus
    I am having trouble displaying the results from the search, it tells me 2 files found but does not display the details of the locations of the files etc. Please can you tell me how to do this ? (Screen shot attached)
