• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    a.prokop
    How to change the language of tooltips on the ribbon?
    344 Views, 9 Replies
    10-22-2012 11:12 AM
    Welcome.
    I have Polish version of Autodesk Inventor 2013 Profesional.
    Tooltips display ribbons to me in English.
    How do I set to display them in the Polish language?
    Thank you in advance for your help.
    Please use plain text.
    *Expert Elite*
    blair
    Re: How to change the language of tooltips on the ribbon?
    10-22-2012 04:37 PM in reply to: a.prokop
    Did you download and install the language package?
    http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=18550979&linkID=9242019
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
    Active Member
    a.prokop
    10-23-2012 01:43 AM in reply to: a.prokop
    I tried.
    I can not install the Polish version because that is already installed.
    So he sees the system.
    *Expert Elite*
    blair
    10-23-2012 08:34 AM in reply to: a.prokop
    It could be a bug, are you on the current SP 1.1?
    Win7-64
    Active Member
    a.prokop
    10-23-2012 09:29 AM in reply to: a.prokop
    SP 1.1 is installed.
    I did a test. I have uninstalled all the patches and service packs.
    The error is still there.
    Once installed SP 1.1.
    *Expert Elite*
    blair
    10-23-2012 09:39 AM in reply to: a.prokop
    I hope that someone from Autodesk looks at this thread, it must be a bug. Check with your reseller or if you are on support, log a support call.
    Win7-64
    Active Member
    a.prokop
    01-05-2013 01:10 AM in reply to: blair
    Recently swapped the files in the Templates folder to the new and the problem disappeared. Tooltips have the correct language.Unfortunately, only for a moment. After a few days I have tooltips again in another language. It will give it to someone can answer why this is happening.
    Distinguished Contributor
    Mason-Paul
    01-05-2013 04:07 AM in reply to: a.prokop
    This could also be connected to your keyboard language settings with in Windows see the attached.
    Thanks in advance for any help & advice
    Inventor 2012 Pro
    Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
    Active Member
    a.prokop
    01-07-2013 12:01 AM in reply to: Mason-Paul
    Unfortunately, it's not. Language settings are fine. The error must be somewhere else.
    Active Member
    a.prokop
    01-24-2013 07:08 AM in reply to: a.prokop
    Where are the files Tooltips?
    Maybe something manually swapping files help?
    I found only the files to Fusion.
    They are in the directory:
    C:\Program Files\Autodesk\Inventor Fusion 2013\pl-PL\Configuration\ToolTips
    However, I can not find the files to Invetor.
