• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    WAYNE_HOUWD
    How to add material thickness to a face?
    136 Views, 5 Replies
    02-13-2013 09:03 AM
    Hi all,
    How can I add a material thickness to a face trimmed from IGES file?
    I have a surface imported from IGES file, then trimmed to a single face in IV that I would like to materialize.
    I tried times for thickness, but IV doesn't like it.
    Neither can I apply Shell for part, nor thickness adding from Sheet metal.
    It is a 3D Lofted surface, very simple single one.
    Any thoughts, please advise.
    Best Regards,
    Wayne
    Please use plain text.
    Re: How to add material thickness to a face?
    02-13-2013 09:10 AM in reply to: WAYNE_HOUWD
    Thicken/Offset
     (how would Shell give you thickness of a surface?)
    Active Contributor
    WAYNE_HOUWD
    02-13-2013 09:37 AM in reply to: JDMather
    Thanks, Prof. JD.
    Active Contributor
    WAYNE_HOUWD
    02-13-2013 10:01 AM in reply to: JDMather
    Hi JD, how can I flatten this part ?
    Wayne
    02-13-2013 12:30 PM in reply to: WAYNE_HOUWD
    You didn't indicate the thickness of the material, but use the Sheet Metal Lofted Flange tool (see attached).
    Active Contributor
    WAYNE_HOUWD
    02-13-2013 12:41 PM in reply to: JDMather
    Thanks for the work on the demo part. Unfortuately, I am still using Inventor 2012. So the file you attached I cannot open.
    By the way, we can assume the material is 12GA, 0.1046".
    Thanks again, Prof. JD.
    Wayne
