• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    ramkrish
    How to Merge cells in Hole Table
    221 Views, 6 Replies
    11-08-2012 06:38 PM
    hi,
    i created hole table but i unable to merge the cells. but i need my output will beas per the input.please help me if you have any idea and make sure it is possible to give ineventor 2011 & 2012.
    please find the attached .JPEG file.
    thank you,
    regards,
    ram
    Please use plain text.
    *Pro
    Re: How to Merge cells in Hole Table
    11-09-2012 05:02 AM in reply to: ramkrish
    Have you tried the various options in the Edit Hole Table dialog?
    Combine Notes will merge the Descriptions for identical holes.  Play around with the other options and see what works for you.
    Cadmanto
    11-09-2012 05:07 AM in reply to: ramkrish
    Ram,
    Another option is you can create the table in Excel and import it into your drawing.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    ramkrish
    12-02-2012 06:19 PM in reply to: sbixler
    sam,
    i tried but i can not merge the cells.
    thank you,
    ram
    ramkrish
    12-02-2012 06:22 PM in reply to: Cadmanto
    Scott,
    export the table in excell is possible. but, in future itis not possible to automatic update. and font size & style also vary.
    thank you,
    ram
    Cadmanto
    12-02-2012 06:33 PM in reply to: ramkrish
    When I have imported Excel spread sheets into Inventor drawings when I needed to edit them, they always opened in Excel.  So I am not exactly sure what you are talking about.
    Best Regards,
    Scott McFadden
    *Pro
    12-03-2012 03:45 AM in reply to: ramkrish
    There must be something unique about your model or styles.  I have used hole tables quite a bit in the last few months, and have no trouble combining hole notes.
    Can you post a drawing and model that exhibit this problem?  Perhaps someone here can identify the solution.
