• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Accepted Solution
    How to Functionally Constrain a "Split Wedge" Assembly?
    276 Views, 10 Replies
    12-07-2012 06:27 AM
    Hey everyone:
    I'm working on a simple assembly that's got some moving parts and I'm having a hard time getting the constraints to work right.
    It's a simple "wedge" assembly where the wedge is constrained to a single axis with a return spring keeping it biased one way.  The are two blocks that are pulled tight against the taper of the wedge with springs that keep them pressed against the taper.  When the wedge moves in they split, when it moves out, they contract.  Simple, right?
    For the life of me, I can't seem to constrain the parts correctly to the taper so it behaves correctly.  The design is proprietary, so I've made up a "lite" version of it and attached it here.
    Can anyone help?  Thanks!
    Inventor 2013 64-bit SP1.1, single user
    Win 7 Pro 64-bit SP1
    Please use plain text.
    Distinguished Mentor
    Re: How to Functionally Constrain a "Split Wedge" Assembly?
    12-07-2012 07:13 AM in reply to: tdswanson
    Your wedge fits exactly with the blocks. They will not move with respect to movement of the wedge.
    I don't understand you intent.
    Valued Contributor
    12-07-2012 07:26 AM in reply to: rdyson
    I've attached a revised copy with the tapered face of the blocks constrained (via Tangent) to the taper of the wedge.  However, this seems to work in reverse of reality.
    When the wedge is lifted UP, the block moves out.  In reality as the wedge is lifted UP, that block is going to slide in.  Obviously it's not in this assembly model, but imagine a spring on the external face of the block that's keeping the two tapered faces together.
    Thus when the wedge goes UP, the block should slide towards the Y axis.
    Is this clearer?
    Thanks!
    12-07-2012 07:35 AM in reply to: tdswanson
    Sorry, I still have no idea what you'er expecting to happen.
    *Expert Elite*
    12-07-2012 07:53 AM in reply to: tdswanson
    Remove the Tangent constraint.
    Add the two Split*.ipt parts to Contact Set.
    Activate Contact Solver
    or
    go into Environments>Dynamic Simulation and add a joint for the contact.
    Valued Contributor
    12-07-2012 08:26 AM in reply to: JDMather
    OK, so that seems like it's pretty much it.  I've added a shoulder screw that'll hopefully clear things up a bit.  (see attachment).
    I added the blocks and the wedge to a contact set, activated contact solver, then drug them in until they touched.
      As I drag the wedge down, the blocks split, but they don't contract when the wedge returns UP.
    So I added a planar constraint with motion limits and used the original offset as a resting position.  This works to drag it around with contact solver active, but I can't drive the constraint on the travel of the wedge for a simulation.  It errors out.
    Is there another way to drive the motion a few times?
    Also - I don't have "Dynamic Simulation" on my Environments tab.  Was this a separate purchase item?
    Thanks very much for looking this over with me!
    *Expert Elite*
    12-07-2012 09:07 AM in reply to: tdswanson
    Must have Inventor Professional to have the Dynamic SImulation.
    You can fudge this with Inventor Studio motions, but I think if you really need to simulate something here you are going to need D.S.
    Valued Contributor
    Mark.Downes
    12-10-2012 03:32 AM in reply to: tdswanson
    I use this kind of assembly a lot with jigs and fixtures, if I have this correct to what you want; it’s a simple split face on the conical faces and a coincident mate of the edges (see attached).
    Hope this helps
    Cheers
    Mark
    Inventor 2013
    Valued Contributor
    12-10-2012 12:10 PM in reply to: Mark.Downes
    Mark:
    I split the faces on the block and on the wedge.  And I can constrain one of the split lines to the other split line, but then nothing can move.  Am I missing something?
    Thanks!
    Valued Contributor
    Mark.Downes
    12-11-2012 12:04 AM in reply to: tdswanson
    Mornin,
    The olny thing i can think of why its not working for you is you may have too many Mates.
    It works for the model i uploaded from your asembly!
    Give that one a go, If i think back i took of the active contact solver (and mates).
    cheers
    Mark
