• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    How to Coil a Coil
    147 Views, 4 Replies
    01-14-2013 04:09 AM
    I have a question, can we coil a coil in nventor?
    If I have a coil or spring, the I want to coil that coil/spring around another axies, can I??
    I use Inv.2012
    Thank you in advance
    Please use plain text.
    *Pro
    Re: How to Coil a Coil
    01-14-2013 05:09 AM in reply to: sohmoh
    Search this forum.  There have been a number of threads over the last several years dealing with this problem.  I'd try using the Bend tool, I think.  I'm not sure whether you can bend more than 360°, though.  But be aware that this is going to be a resource hog-- helices are really math-intensive.  If you don't need a functional model, you might consider using a textured appearance instead, kind of like the cosmetic threads that Inventor uses on screws.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    01-14-2013 05:24 AM in reply to: sbixler
    Well, Thank you for your quick response
    But I tried the Bend comand, it could not help me.
    Thank you again for your time sir.
    *Expert Elite*
    01-14-2013 06:26 AM in reply to: sohmoh
    A better way is with an Excel formula of points to generate a sweep curve.
    In Inventor 2013 you can enter the formula directly (unfortunately I don't know it by heart - a search should return the forumla to use).
    01-14-2013 06:39 AM in reply to: JDMather
    Thank you for your replay :smileyhappy:
