• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Vitornis
    How do you word wrap leader text?
    375 Views, 6 Replies
    04-16-2012 09:46 AM
    very simple,
    Please use plain text.
    cbenner
    Re: How do you word wrap leader text?
    04-16-2012 10:03 AM in reply to: Vitornis
    Enter key.... carraige return.  Will push text to the next line.  Works like any other text editor.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Valued Contributor
    Vitornis
    04-16-2012 10:09 AM in reply to: Vitornis
    Well I meant something more intuitive like word wrap for you based on a certain text box width. Espically for text that is link to a property from my model. Hell any other text editor will autowrap for you when you get to the edge of the page.
    Distinguished Contributor
    04-16-2012 12:17 PM in reply to: Vitornis
    Replying in case someone else has a good answer . . .  (I don't . . .)
    Curtis_Waguespack
    04-16-2012 12:45 PM in reply to: Vitornis
    Hi Vitornis,
    I think you need to create a sketch, sketched symbol, or something similar and use the Text tool within that environment before you can use the Text Box option. For some reason the standard drawing text tool and leader text tools both lack the ability to define a text box.
    Within a sketch you can use the Text Box button in the text editor, or right-click on the text and choose Text Box. Then you can define the length of the text box with a dimension or just click and drag a corner to eyeball it.
    If you have this need often, it's probably worth creating a sketched symbol to use, and just include a leader when placing it.
    Adding the Text Box option to the standard drawing text tool  would probably make a good feedback request:
    http://inventortrenches.blogspot.com/2011/01/feature-request-for-inventor.html
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    04-16-2012 02:13 PM in reply to: Curtis_Waguespack
    This helped me Curtis. Thank you for contributing.
    Valued Contributor
    Vitornis
    04-16-2012 02:31 PM in reply to: Vitornis
    Ooo never really thought about using a sketch symbol. Can't wait to try this thanks for the suggestion!
