• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    How do i add a customized tube size for frame generator
    361 Views, 2 Replies
    09-10-2010 10:38 AM
    I have just started working with inventor and i have a file that i am working on that I can not locate the right size square tunbing for.  The standard sizing seems to start @ 2" square and i need 1.5" and 1.25" square tubing for a handrail I am building.  Can any one help me add these sizes in.
    **Master
    Re: How do i add a customized tube size for frame generator
    09-10-2010 10:43 AM in reply to: robclark8089
    this has changed over the years, so it depends what version of Inventor you're using, but these should help:
    http://usa.autodesk.com/adsk/servlet/item?linkID=9242016&id=14351277&siteID=123112
    http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12193815
    New Member
    09-10-2010 10:45 AM in reply to: BMiller63
    I am on Inventor 2011 Profesional.  These should help.  Thank you
