• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    mcrump28210
    How do I tell What Layer a Line is On.
    88 Views, 2 Replies
    07-03-2012 07:54 AM
    When I edit a title block I would like to know which layer a particular line is on.  If I right click to activare the "Properties" dialog box.  All it tells ne is that the line is "By Layer".  How can I tell which layer an entity is on?
    Thanks!
    Michael Crump
    Michael Crump
    AutoCAD 2013
    Inventor 2013
    Windows Pro 7 x64
    Asus Sabertooth X58
    Intel Core i7 960 @ 3.2 GHz
    24 GB ram
    Please use plain text.
    Curtis_Waguespack
    Re: How do I tell What Layer a Line is On.
    07-03-2012 07:57 AM in reply to: mcrump28210
    Hi mcrump28210,
    Select the line(s) and then switch to the Annotate tab, and look for the Format panel. You'll see the layer drop down box listing the current layer. You can use the drop down to change the layer if needed.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Contributor
    mcrump28210
    07-03-2012 08:02 AM in reply to: Curtis_Waguespack
    Thanks Curtis!  BTW, I have all of your books and they have been of tremendous help to me.  Thanks Again!!
    Michael Crump
    AutoCAD 2013
    Inventor 2013
    Windows Pro 7 x64
    Asus Sabertooth X58
    24 GB ram
