• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    StefanoMenci
    Accepted Solution
    How do I purge/clear the definition of a deleted component?
    207 Views, 2 Replies
    09-16-2011 01:31 PM
    I would like to get rid of the following problem:
    1) Create a new assembly
    2) Place the component Part1
    3) Delete the component jast inserted (now Part1 is not used)
    4) Create a new part
    5) Save as Part1 -> it says "cannot give a document the same name as an open document (or a document that is referenced by an open document, e.g. a part/assembly referenced by a drawing). Enter a different name for the document you owant to save."
    This is a simplified sequence. My real application is a VBA macro that does something similar. The first time works, the second time gets stuck because it remembers the component just deleted.
    Stefano
    Please use plain text.
    *Expert Elite*
    blair
    Re: How do I purge/clear the definition of a deleted component?
    09-16-2011 01:36 PM in reply to: StefanoMenci
    Close and re-start Inventor is the only way I have been able to solve this issue
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Active Member
    StefanoMenci
    09-16-2011 02:22 PM in reply to: blair
    Found: Inventor - Manage - Refresh.
