• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    How do I get horizontal Hole Note text
    110 Views, 1 Replies
    10-30-2002 08:04 PM
    If I create a hole note when using Inventor default ANSI standards I get a hole note with horizontal text (looks like leader text), however, I actually create my own standard based on ANSI (change units to mm, change text height etc.) and my hole notes come in with just one vertex with the text aligned to it (like default ISO does it) What needs to be changed to move text from aligned to horizontal?
    Regards
    Matt Hutchinson
    Please use plain text.
    Re: How do I get horizontal Hole Note text
    10-30-2002 08:13 PM in reply to: MattH
    Ignore last post, sorted it. Setting the orientation of diameter dimensions does the trick.
    Regards
    Matt Hutchinson
