• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Mentor
    How do I find Dimension Over rides in idw
    115 Views, 2 Replies
    01-24-2013 11:11 PM
    I have some drawings with lots of dimensions.  Is there a way to check if any have been over ridden or a global way to set all dimensions to model value?
    Steve
    Please use plain text.
    *Expert Elite*
    ScottMoyse
    Re: How do I find Dimension Over rides in idw
    01-24-2013 11:39 PM in reply to: stevec781
    This should do it  for you:
    http://inventortrenches.blogspot.co.nz/2011/06/using-ilogic-to-find-dimension.html
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    *Expert Elite*
    Curtis_Waguespack
    01-25-2013 07:23 AM in reply to: stevec781
    Hi stevec781,
    The iLogic snippet that ScottMoyse refered to was originaly written to be used as part of a larger task, and although it will work to do what you ask, there actually is a built in solution for this as well:
    • Hold the Shift key and then Right-Click
    • Then choose Select All Overidden Dimensions from the menu.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
