Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How do I break the sheet numbers in an idw
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have several sheets w/in a drawing. Some of the sheets are titled sheet 2A, 2B, etc. I'd like to be able to do this w/o needing several title blocks. Where I'd really need help is that what becomes sheet 3 is now sheet 5. How do I offset the sheet numbers?
Re: How do I break the sheet numbers in an idw
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi jpblower,
The easiest way to do this is to insert a blank sheet, and then Right Click on it and choose Edit Sheet, then set it to not be included in the print, but still be counted.
I like to remove the titleblock and place a note to help "the next guy" figure out what is going on, as well.
I hope this helps.
Curtis
Edit:
It just occured to me that you might be wanting to go the other way, in which case you'd just set sheet 2B to Exclude from Count, etc.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
