Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
How can i insert a frame generator in bends????
- Highlight
- Email to a Friend
I want to insert a channel section in bends... but i cant select that surface to insert frame... So What can i do... Pls suggest me how to do..... Thank you in Advance....
Re: How can i insert a frame generator in bends????
- Highlight
- Email to a Friend
The problem with Frame-Gen is that each line segment creates a single part (member) within Frame-Gen. The picture shows 2 different runs. The lower Z is a group of 3 lines and 2 fillets on a sketch. This will produce 5 items within the F-G module (line items 001 to 005).
The upper tube (funny curved run) is a single poly line. Since this is a single line only one tube member (006) was added to the Frame-Gen module.
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 314.07
SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
- Highlight
- Email to a Friend
blair wrote:The problem with Frame-Gen is that each line segment creates a single part (member) within Frame-Gen. ....
If you don't select Merge.
If you do select Merge - only one frame member is created.
- Highlight
- Email to a Friend
Thanks, learned something new today (don't use F-G alot).
Win7-64
- Highlight
- Email to a Friend
Merge is great but causes some problems. You can't then use some of the other Frame commands like Trim/Extend, Mitre and such. To acheive these you have to do in place editing of the FG member and scuplt and such. I'm using 2012 and am unsure if this has been fixed in 2013.
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
