• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    How can i insert a frame generator in bends????
    146 Views, 4 Replies
    11-16-2012 08:12 PM
    I want to insert a channel section in bends... but  i cant select that surface to insert frame... So What can i do... Pls suggest me how to do..... Thank you in Advance....
    Please use plain text.
    blair
    Re: How can i insert a frame generator in bends????
    11-17-2012 01:50 PM in reply to: Chand777
    The problem with Frame-Gen is that each line segment creates a single part (member) within Frame-Gen. The picture shows 2 different runs. The lower Z is a group of 3 lines and 2 fillets on a sketch. This will produce 5 items within the F-G module (line items 001 to 005).
    The upper tube (funny curved run) is a single poly line. Since this is a single line only one tube member (006) was added to the Frame-Gen module.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    11-17-2012 02:12 PM in reply to: blair
    blair wrote:
    The problem with Frame-Gen is that each line segment creates a single part (member) within Frame-Gen. ....
    If you don't select Merge.
    If you do select Merge - only one frame member is created.
    blair
    11-17-2012 02:34 PM in reply to: JDMather
    Thanks, learned something new today (don't use F-G alot).
    Win7-64
    Distinguished Contributor
    BLHDrafting
    11-18-2012 04:23 PM in reply to: blair
    Merge is great but causes some problems. You can't then use some of the other Frame commands like Trim/Extend, Mitre and such. To acheive these you have to do in place editing of the FG member and scuplt and such. I'm using 2012 and am unsure if this has been fixed in 2013.
    Brendan Henderson
    Web www.blh.com.au
    Twitter @BLHDrafting
    Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
    ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
    Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
