• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    How Do I Get This Project Started?
    290 Views, 10 Replies
    12-06-2012 12:17 AM
    I need to create a rather unique shape that doesn't seem to lend itself well to CAD.
    It's a Mangels whip Car, the old amusement park ride from the early 1900s. I'm fairly new to CAD and I'm stumped as to how to get the shape of the main tub of the car, I've attached a pic to help you visualize it. It seems I would need to create a 2-D representation of the walls of the car and then conform them to an egg-shaped floor, but perhaps I'm missing a simpler solution. Thanks for any help.
    Picture Attached.
    Please use plain text.
    Re: How Do I Get This Project Started?
    12-06-2012 04:10 AM in reply to: steambc
    Looks rather simple to me.
    How much training have you had?
    What version of Inventor are you using?
    Are you familiar with Loft and Patch tools?
    Can you attach the file here of what you have attempted so far?
    12-06-2012 04:16 AM in reply to: steambc
    Is inventor fusion not a good option to create the basic form?
    Inventor 2011 (x64)
    Productstream Professional 2011 (x64)
    Windows 7 (x64)
    Product design suite Professional 2013
    12-06-2012 04:18 AM in reply to: mnthailand
    I don't understand why anyone would use Fusion if they have Inventor?
    12-06-2012 05:13 AM in reply to: steambc
    Sorry, you are right. Inventor would be the best option. You suggest loft and patching. I was just wondering...
    Is it easy to create a solid, create chamfer(s) and fillet(s) and shell the solid?
    BR
    Mario
    Inventor 2011 (x64)
    Windows 7 (x64)
    12-06-2012 06:06 AM in reply to: JDMather
    Inventor 2013
    Training has been CAD Gorilla Inventor for Beginners.
    I have done simple lofts, don't remember playing with patch tools although I can go back through that tutorial if it's there.
    All I've done is experimentally created the basic shape of the floor with a spline; a simple egg shape. I'm aware that I haven't the knowledge to achieve the top rail profile, where it's taller in the back and shorter in the front.
    That's why I'm asking how a designer would approach the job in the first place, i.e. what tools would he use, or what would be his design intent and mindset as he approached the job conceptually?  I'm creating this in order to visualize various color schemes for the real 1920 Whip Car that I'm restoring. I simply want to create a model that I can orbit around with different color combos.
    Distinguished Mentor
    12-06-2012 06:44 AM in reply to: steambc
    The basic shape doesn't require a spline, just two arcs and two lines symmetrical about a centerline. Loft this to a similar sketch at the appropriate height. Create a sketch on the center line. Draw the cut away portion and do a cut through all both directions, shell and done.
    12-06-2012 07:03 AM in reply to: steambc
    This tutorial is a bit more complex than your design but should give you some good ideas to get started.
    http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf
    12-06-2012 07:13 AM in reply to: rdyson
    Beautiful! I can visualize exactly what you're talking about and clearly that will work for me. I appreciate the help.
    12-06-2012 07:14 AM in reply to: JDMather
    Thanks. I will definitely study that tonight. I appreciate it.
