• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Accepted Solution
    Holes
    187 Views, 13 Replies
    02-08-2012 01:15 PM
    I have a trial verzion of Inventor 2012 and doing a little evaluation project which requires a square hole and also a round screw hole both in a radiused surface. The first, I can not find any info on a square hole and the second the screws hole in a radius the hole is placed but a recesses head hole does not come out on the side I need, it goes on the opposite side I place it in? Can you help.
    Larry
    Distinguished Contributor
    Ktelang
    Re: Holes
    02-08-2012 01:27 PM in reply to: ljboen
    Square holes, I am not sure what you want here. But I have assumed it to be a square pocket(extrusion with cut option)
    Hole on a curved surface can be achieved as shown in the file attached.
    Hope that help
    Config :: Intel (R) Xeon (R) CPU E5506 @ 2.13 GHz, 8 GB, 64bit win7
    Ktelang
    Re: Holes
    02-08-2012 01:31 PM in reply to: Ktelang
    I missed the square pocket on rounded surface
    please find the updated file
    ***Guru
    Re: Holes
    Here are the answers to the questions as I understood them.
    1-A square hole is done with a square sketch and the cut or extrude feature.
    2-For your flat head screw...You need to switch to the aligned solution in the insert constraint instead of opposed. (the other of the 2 buttons right below the 2 selection arrow buttons in the place constraint dialog box.
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    Core I7 920 processor, ATI HD6970 graphics card, 12G RAM
    ****Sage
    Re: Holes
    02-08-2012 01:34 PM in reply to: ljboen
    If you have trouble figuring it out - attach what you are able to complete (even if it isn't right).
    Also as you get more experience a Punch feature (even if it isn't sheet metal) might be a slick way to produce the feature.
    Autodesk Inventor Certified Professional
    Inventor Professional 2012 Edu 32-bit
    Still waiting for -Draft option on any Rib feature. -Properties Painter.
    Still wondering why Edit Form is above Edit Feature on RMB?
    Re: Holes
    02-09-2012 01:34 PM in reply to: mcgyvr
    In Reference to #2.
    Where is this aligned solution in the insert solution? I am new at this being on a trial program.
    Re: Holes
    02-09-2012 01:35 PM in reply to: ljboen
    I meant to say where is this insert restraint?
    ****Sage
    Re: Holes
    02-09-2012 04:43 PM in reply to: ljboen
    or maybe you really meant to say Insert Constraint.
    In assembly environment.
    I recommend you start by going through the Help>Tutorials
    It will take far longer than 30-days to evaluate the program.
    Re: Holes
    02-09-2012 06:13 PM in reply to: JDMather
    But I am trying to place a hole in a part that has a curved surface and I am not in the assembly environment. Isn't there a way to place the hole when creating the part?
    Distinguished Mentor
    Re: Holes
    02-10-2012 06:08 AM in reply to: ljboen
    To create a hole on a curved surface, you need to define the location of the hole start, and the direction.  There are several ways to do this, but creating a workplane perpendicular to the direction and located at your desired start point is not usually too difficult.
    But for anyone to help with your particular situation, you'll have to post the file you're working on (and Inventor version) and tell us exactly what you're trying to create.
    Sam B
    Inventor 2012 Certified Professional
    Inventor Professional 2012 SP1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool
