• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    RD-Digitek-USA
    Accepted Solution
    Hole Table X-Y dimensions trailing zeros. Can I turn off
    263 Views, 5 Replies
    01-18-2012 11:08 AM
    I figured out how to change the precision of the X-Y location dimensions in a hole table, but is there a way to turn off trailing zeros? I have turned them off in my styles, but for some reason the styles don't effect hole tables. Maybe I just don't know where to look?
    Please use plain text.
    *Expert Elite*
    blair
    Re: Hole Table X-Y dimensions trailing zeros. Can I turn off
    01-18-2012 01:45 PM in reply to: RD-Digitek-USA
    Slightly hidden the first time: RMB select the X-Y hole table, select Edit Hole Table Style, then you need to RMB on the XDIM and YDIM and select the Format Column. You should then be able to set your Precision
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    RD-Digitek-USA
    01-19-2012 06:45 AM in reply to: RD-Digitek-USA
    Thanks for the reply,
    But what I am looking for is a way to turn off the trailing zeros. Example, If I have dimensions that are 23.00 and 23.50 I want them to be displayed as 23 and 23.5. I know you can set precision on each individual cell, but wat too time consuming. If I edit styles I have the option to turn off trailing zeros for dimension styles but that option does not exist for hole table styles???.
    *Expert Elite*
    blair
    01-19-2012 08:38 AM in reply to: RD-Digitek-USA
    Tables follow the explicit formating of the table/cell, you don't have the ability to drop trailing Zeros.
    Win7-64
    *Expert Elite*
    Curtis_Waguespack
    01-19-2012 08:52 AM in reply to: blair
    Hi blair,
    I think your first suggestion was correct, other than one slight correction:
    • Right-click the hole table
    • Select Edit Hole Table Style
    • Then Right-click on the XDIM and YDIM row
    • Select the Format Column
    • Use the buttons to suppress or include leading or trailig zeros
    You might need to switch the hole table from the current style to a different one and then back to "refresh" the style/overrides the existing table is using.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    RD-Digitek-USA
    01-19-2012 10:44 AM in reply to: Curtis_Waguespack
    That's it right in front of my big nose, thank you very much!!!:smileyvery-happy:
