• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Mears, Brian
    Hole Notes
    68 Views, 5 Replies
    10-30-2002 10:01 PM
    I like that I can now create custom hole
    notes.  However, is it true that I cannot create more than one type of note
    for a specific hole?  For example, let's use a simple thru hole.
    Often that hole would be a simple drill thru (which is what my note is set up
    for).  However, sometimes we'll put a threaded fastener into that hole, so
    I would need a note to call that out.  I realize that I can edit the custom
    note I created, but I'd practically be retyping the whole thing.
    Did that make sense?  Those of you that came
    from MDT... you can create holenotes there to your heart's content... you can
    have any number of notes for a single hole type, and you can pick the one you
    need.  It appears that you can't do that in inventor.  Is that indeed
    the case?
    One more question... the default leader attachment
    point for the holenotes is UPPER left or right.  Our standards are middle
    of all text.  It appears that you can't control the attachment point on
    holenotes (I do realize that you can change it after placement, but it's an
    extra step). Can the default attachment point be changed?  Perhaps thru the
    registry?
    Thanks in advance for the help.  I'm
    evaluating Inventor for a possible switch from MDT, and these things all play a
    part in determining whether or not we switch.
    Brian
    Please use plain text.
    *Keller, Kent
    Re: Hole Notes
    10-31-2002 12:59 AM in reply to: *Mears, Brian
    Brian
    It appears to me that we still only have one template per hole type. 8^(
    And if you figure out how to get your leader to the middle let me know because mine goes
    to the middle and I want it at the top At least we know it can be where we want 8^)
    Kent
    Member of the Autodesk Discussion Forum Moderator Program
    "Brian Mears" wrote in message
    news:183F3CEB6510F002070C5CDA3A85BBA7@in.WebX.maYIadrTaRb...
    > I like that I can now create custom hole notes. However, is it true that I cannot
    create more than one type of note for a specific hole?
    > One more question... the default leader attachment point for the holenotes is UPPER left
    or right. Our standards are middle of all text.
    *Dotson, Sean
    Re:
    10-31-2002 01:01 AM in reply to: *Mears, Brian
    Haven't tried it but if you format a text style to have top, middle or
    bottom justification and then specify this text to be used in a dimension
    style it should justify in this manner...
    Sean Dotson, PE
    http://www.sdotson.com
    remove all #s from email
    "Kent Keller" wrote in message
    news:A46FA8673F50E059703251CADA7E563B@in.WebX.maYIadrTaRb...
    > Brian
    because mine goes
    where we want 8^)
    > Kent
    that I cannot
    *Caldwell, Larry
    Re:
    10-31-2002 01:06 AM in reply to: *Mears, Brian
    That's right ... I use it all the time: the middle button in the
    justification line of icons has Top, Middle and Bottom.
    ~Larry
    "Sean Dotson" wrote in message
    news:EEF2D5F73B1A99A3B71E7134A4AFA7F5@in.WebX.maYIadrTaRb...
    > Sean Dotson, PE
    > > Brian
    8^(
    > because mine goes
    > where we want 8^)
    > > Kent
    > that I cannot
    *Keller, Kent
    Re:
    10-31-2002 01:11 AM in reply to: *Mears, Brian
    That was it 8^)... My dimension style for some reason was set to
    You know I find the three dialogs.... Standards, Dimension styles, and Text to tied to
    each other. It just seems like every time I make a change I end up going through all
    three dialogs and hunting. Maybe I just haven't used them enough yet, but their layout
    has always seemed off to me.
    Kent
    > Sean Dotson, PE
    > > Brian
    > because mine goes
    > where we want 8^)
    > > Kent
    > that I cannot
    *Dotson, Sean
    Re:
    10-31-2002 01:28 AM in reply to: *Mears, Brian
    I agree. The way you have to set up one to then use it in the other is a
    bit confusing at first..then once you figure it out you don't change it for
    so long that by the time you go back to change it again you've forgotten how
    to do it...(now I sound like Larry)
    Sean Dotson, PE
    news:CE1CD6D9143B46AE39E142A2EF7557F0@in.WebX.maYIadrTaRb...
    Text to tied to
    going through all
    their layout
    > Kent
    dimension
    > > Sean Dotson, PE
    > > > Brian
    8^(
    > > because mine goes
    > > where we want 8^)
    > > > Kent
    > > that I cannot
