• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: Hole Function
    11-21-2012 10:43 AM in reply to: cbenner
    cbenner wrote:
    ....but I'm surprised your Revolution1 worked at all since the sketch is an open loop....
    Many of the Extrude and Revolve will work with open profiles if Match Shape is checked.  But in this case it seems to be a bug.
    Please use plain text.
    cbenner
    Re: Hole Function
    11-21-2012 11:50 AM in reply to: JDMather
    I guess I've never seen that before.  But when I closed the loop and redefined the feature, the hole command worked as expected on the part.  So, that made me suspect the feature as being part of the problem.
    I learned something new today.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
