• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    sgold
    Accepted Solution
    Hole Diameter Tolerance Reset
    176 Views, 2 Replies
    07-02-2012 10:58 AM
    I keep hving trouble with a hole and the diameter tolerance.
    Create a simple hole, single diameter concentric and specific depth.  I go to the tolerance window for the diameter and change it to a Limits-Linear.  I enter my values .3758 and .3754.  Precision is .1234.  I clikc OK, then go back to the tolerance, and its reset both values to .3756  What gives????  I've deleted and recreated the hole, edited it about 10 times, and still the same effect.  What could I be doing wrong?  Thanks!
    --Scott
    Scott G.
    Using Inventor 2013 and Vault Basic (New to Inventor)
    6 years Solidworks (v2006-2010)
    10 years Pro-Engineer (v13-WF2) w/ Intralink (2.0-3.0)
    2 years of Mechanical Desktop
    AutoCAD since R12
    First professional CAD: DrafixCAD
    Please use plain text.
    Distinguished Mentor
    Re: Hole Diameter Tolerance Reset
    07-02-2012 01:13 PM in reply to: sgold
    Tools / Options / Document Settings / Units
    sgold
    07-03-2012 05:26 AM in reply to: rdyson
    Ah, I double checked again, this model didn't have the 4 place in the precision in the Document Settings.  Seems pretty stupid that you need to dig and figure that out when your tolerances are resetting.  It kept showing the full 4 places in the window for the dimension edit, so never considered a document setting being the issue!  Shouldn't the setting WITHIN a particular feature override the document global?  If I need one 5 place decimal, I should have the entire document on 5-place?  That's stupid!
    Thanks rdyson!
    --Scott
    Scott G.
    AutoCAD since R12
