Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Hiding BOM column
- Highlight
- Email to a Friend
Is it possible to have a column in the BOM but i do not want to show it on the drg.
like you can do it for rows for example...
thank,s
ric
Re: Hiding BOM column
- Highlight
- Email to a Friend
Edit the parts list in the drawing and use the column chooser to remove the column you don't want.
- Highlight
- Email to a Friend
I do want to have the column in the drawing in the bom but I do not want to show it.
- Highlight
- Email to a Friend
Removing the column from the parts list in the drawing does not remove it from the BOM.
- Highlight
- Email to a Friend
I start again ![]()
drawing environment:
I want to have a column, but do not want to show it on the drg,
but if I edit the BOM in the drg (not assy) I want to see it, so if I expot it it will be there, but if I print it it wont...
we need some extra details for purchasing porpuses ,etc...
thanks,
ric
- Highlight
- Email to a Friend
I guess I don't understand.
- Highlight
- Email to a Friend
I have the same question. For instance, sometimes when I edit the drawing parts list, I want to be able to see the part numbers and maybe even the filenames of each item in the list. But, I don't want either the part number or filename columns to be visible on the sheet.
It is possible to turn off the visibility of rows in a parts list, but we are wondering if it is also possible to turn off the visibility of columns.
- Highlight
- Email to a Friend
Hi richiesuk,
Let's define terms first:
BOM = the table in the assembly that contains bill of materials info
Parts List = the table on the drawing that displays BOM info
With that said, I've not found a way to hide columns in a Parts List, other than using the Column Chooser to remove them.
I think the best approach is to format your parts list to show only the columns you want to show on the page, and then access the BOM editor to see and edit other columns (right click on the Parts List > Bill Of Materials).
The other trick I've used is to create an alternate parts list style that shows the columns, and then just switch the parts list to that style (select it then go to the Annotate tab > Styles pull down), then edit the parts list, then switch it back to the original style that doesn't show the "hidden" columns.
I hope this helps.
Curtis
- Highlight
- Email to a Friend
Hi
Simple solution, change the column width to "1".
Reg
Autodesk Product Design Suite Premium 2013 sp1.1 (1)
Intel Core i7 (950@3.07GHz)
Windows 7x64 (Home)
12GB Ram
Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
- Highlight
- Email to a Friend
Screen caps
Reg
Windows 7x64 (Home)
12GB Ram
