• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Accepted Solution
    Hiding BOM column
    203 Views, 10 Replies
    09-25-2012 06:45 AM
    Is it possible to have a column in the BOM but i do not want to show it on the drg.
    like you can do it for rows for example...
    thank,s
    ric
    Please use plain text.
    Distinguished Mentor
    Re: Hiding BOM column
    09-25-2012 06:52 AM in reply to: richiesuk
    Edit the parts list in the drawing and use the column chooser to remove the column you don't want.
    John Retzlaff
    09-25-2012 06:58 AM in reply to: john.retzlaff
    I do want to have the column in the drawing in the bom but I do not want to show it.
    09-25-2012 07:35 AM in reply to: richiesuk
    Removing the column from the parts list in the drawing does not remove it from the BOM.
    John Retzlaff
    09-25-2012 07:54 AM in reply to: john.retzlaff
    I start again :smileyhappy:
    drawing environment:
    I want to have a column, but do not want to show it on the drg,
    but if I edit the BOM in the drg (not assy) I want to see it, so if I expot it it will be there, but if I print it it wont...
    we need some extra details for purchasing porpuses ,etc...
    thanks,
    ric
    09-25-2012 07:58 AM in reply to: richiesuk
    I guess I don't understand.
    John Retzlaff
    *Expert Elite*
    09-25-2012 08:52 AM in reply to: john.retzlaff
    I have the same question.  For instance, sometimes when I edit the drawing parts list, I want to be able to see the part numbers and maybe even the filenames of each item in the list.  But, I don't want either the part number or filename columns to be visible on the sheet.
    It is possible to turn off the visibility of rows in a parts list, but we are wondering if it is also possible to turn off the visibility of columns.
    *Expert Elite*
    Curtis_Waguespack
    09-25-2012 09:20 AM in reply to: richiesuk
    Hi richiesuk,
    Let's define terms first:
    BOM = the table in the assembly that contains bill of materials info
    Parts List = the table on the drawing that displays BOM info
    With that said, I've not found a way to hide columns in a Parts List, other than using the Column Chooser to remove them.
    I think the best approach is to format your parts list to show only the columns you want to show on the page, and then access the BOM editor to see and edit other columns (right click on the Parts List > Bill Of Materials).
    The other trick I've used is to create an alternate parts list style that shows the columns, and then just switch the parts list to that style (select it then go to the Annotate tab > Styles pull down), then edit the parts list, then switch it back to the original style that doesn't show the "hidden" columns.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    rhasell
    09-25-2012 08:13 PM in reply to: Curtis_Waguespack
    Hi
    Simple solution, change the column width to "1".
    Reg
    Autodesk Product Design Suite Premium 2014 Build 170
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home) - 12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
    rhasell
    09-25-2012 09:30 PM in reply to: rhasell
    Screen caps
    Reg
