• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Nate711
    Accepted Solution
    Help with editing extrusion
    281 Views, 2 Replies
    10-30-2011 10:13 AM
      I have a part that I am editing constantly in the form of a single extrusion. The problem I am having is hard to explain so I attached a picture. Note this ins't actualy my part, I just made this for clarity. In the picture I extruded a circle. Then I editied the sketch to make another circle inside. Is there a way to make it so it just extrudes the ring without deleting and remaking the extrusion and breaking everything related to it? I want to use just one sketch because I will be laser cutting it later. Thanks.inventor help extrude.PNG
    Please use plain text.
    Valued Mentor
    Re : Help with editing extrusion
    10-30-2011 11:13 AM in reply to: Nate711
    Hi
    very simple
    when you edit the extrusion, clic on profil button ( feature window) and after, pressand hold shift key and deselect the profile you don't want
    See picture
    Yannick Verreault
    INV PRO 2014
    MS Office 2007
    Win 7 pro, core i7 950, asus P6T WS
    nvidia Gforce GTX 295
    WD caviar black 500Go
    WD caviar black 1To
    Nate711
    Re: Help with editing extrusion
    10-30-2011 11:28 AM in reply to: Nate711
    Wow, I feel dumb. Thank you!
