• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    oopisteinepoiss
    Accepted Solution
    Help needed with shell command
    1173 Views, 13 Replies
    11-02-2011 12:21 PM
    I need help with shell command. When i want to shell my product, program gives this error: Shell1: Could not build this Shell. The attempted Shell operation had non-manifold inputs. Try with manifold inputs. How can i fix this problem ?
    Sorry for my bad english.
    Thank you for your time.
     Appreciations.
    Please use plain text.
    *Expert Elite*
    Re: Help needed with shell command
    11-02-2011 12:42 PM in reply to: oopisteinepoiss
    Your English is excellent.
    Your ability to fully constrain sketches is not so great.
    Loft4 is the problem. Pull the end of part marker up over Mirror2 and look at the flat face of your first loft. There is a void there between loft3 and loft 4.
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    *Expert Elite*
    While I take a look at your geometry - you might take a look at this document http://home.pct.edu/~jmather/skillsusa%20university.pdf
    I noticed that your First sketch isn't constrained and it looks like you might be doing too much work to get the geometry.
    Maybe something like this is what you are after (see attached)
    oopisteinepoiss
    11-03-2011 02:06 AM in reply to: JDMather
    Thank you for such short notice, but there is still one question that remains. Why sweep tool connects to solids when loft tool isn't able to do it ?
    Thank you for your answer.
    Appreciate your help.
    *Expert Elite*
    11-03-2011 04:04 AM in reply to: oopisteinepoiss
    Loft  is able to do it - if you set up the problem correctly.  But it looked to me like Sweep would be less work.  Why do more work?
    If the sweep doesn't give you desired geometry, we can keep working on a more complex Loft solution.
    *Expert Elite*
    11-03-2011 05:47 AM in reply to: JDMather
    Took another look - Loft IS easier (see attached).
    New Member
    AminaShab
    01-03-2012 01:41 PM in reply to: oopisteinepoiss
    please help im trying to hollow out a box but no matter what i do it keeps on saying try manifold inputs, also i attached you file but it would not load on my software please tell me step by step hows to make a shell
    thanks
    your answer is valued
    *Expert Elite*
    01-03-2012 01:46 PM in reply to: AminaShab
    Attach your ipt file here.
     If the file size is too large - find the red End of Part marker in the browser.
    Drag the red EOP marker to the top of the browser hiding all features.
    Save the file with the EOP in a rolled up state.
    In Windows Explorer right click on the file name and select Send to Compressed (zipped) Folder.
    Attach the resulting *.zip file here.
    Member
    04-15-2013 09:37 AM in reply to: oopisteinepoiss
    I'm having the same problem trying to shell this part. I've redone the loft based on previous comments but hasn't madea  difference. Any help would be greatly appreciated! Thanks.
    Distinguished Mentor
    04-15-2013 10:08 AM in reply to: keith_velishek
