• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Accepted Solution
    Help making sheet metal part
    227 Views, 3 Replies
    10-12-2012 12:57 PM
    I have a 14 gage sheet metal part that follows the profile in the attached picture.  7/8" legs with a 1/16" offset.  Because it's 14 gage, the contour flange won't create it.  I need it to be able to be turned in to a flat pattern so that I may export it to a .dxf.  Is there another way to make this that will allow me to flat pattern it?  I have a couple of pieces like this where the offset is very slim, so I am looking for a way to do all of them like this.
    Please use plain text.
    *Expert Elite*
    Re: Help making sheet metal part
    10-12-2012 01:22 PM in reply to: nickv02
    That profile is just incorrect. Its not made like that in real life unless its a stamping operation which Inventor cannot properly define the flat pattern for.
    How is this part fabricated?
    Model the 2 faces then use "bend" to connect them if press braked.
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    *Expert Elite*
    Curtis_Waguespack
    Hi nickv02,
    Attached is an example that might give you a hint. I didn't see any information on what version of Inventor you're using, but hopefully you can open an Inventor 2010 file (that's the oldest version I have Installed these days.)
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Valued Contributor
    10-12-2012 01:34 PM in reply to: Curtis_Waguespack
    Inventor 2013, forgot that.
    It's a stamping procedure.  You're right, I was going about it the wrong way and drew it incorrectly.
    Curtis, that example is excellent, thank you for your help!
