• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    rjones0215
    Help drawing a cutterhead for a dredge
    738 Views, 8 Replies
    10-01-2011 07:47 AM
    I am trying to draw this cutterhead.  The 3D sketch and helical curve commands have a allowed me to create part of the "arms" with the teeth on them but I can't seem to get them to come up and over the hub in the middle.  Only to the top of it.  Any tips?  Thanks.
    Inventor 2013 Certified Professional
    Please use plain text.
    Re: Help drawing a cutterhead for a dredge
    10-01-2011 09:29 AM in reply to: rjones0215
    Attach your ipt file here.
    Active Member
    rjones0215
    10-01-2011 11:31 AM in reply to: rjones0215
    10-01-2011 12:29 PM in reply to: rjones0215
    Why did you use Driven rather than Driving dimensions in Sketch10?
    I would have used the edge of a Coil surface body rather than the 3D sketch - much easier to control.
    I would avoid adaptivity for this design.
    Sketch12 is not constrained.
    You might start with this document http://home.pct.edu/~jmather/skillsusa%20university.pdf
    I suspect I would Thicken a trimmed helical surface.
    10-01-2011 06:59 PM in reply to: JDMather
    Do you have a picture from side and top?  You have an assembly - do you have a 2D drawing from which it was made?
    10-02-2011 11:14 AM in reply to: JDMather
    Here is an alternate solution - more information would be needed to get precise representation.
    10-03-2011 06:43 AM in reply to: JDMather
    Have you made an progress on this?
    Active Member
    rjones0215
    10-03-2011 08:31 AM in reply to: rjones0215
    I had to move to something else but will be back on the cutterhead later this week.  Thanks for your input.  I will be keeping you involved with my progress.  And I'm sure I will have more questions for you.
    Active Member
    rjones0215
    11-09-2012 11:35 AM in reply to: rjones0215
    Mr. Mather,
    I realize it's been awhile since I submitted my original post about help with cutter head model.  Since then I have made progress in accomplishing a decent model, but I still think there is a better way to create my cutter head.  I'm attaching the file so that you may view it.  Any input or pointers at all would be greatly appreciated.  Also, I am aware that I have a few sketches that are not constrained.  I am still getting acquainted with 3D sketches.  Thanks again for any info.
