• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Help completing model Thom Tremblay's book Inventor 2012 essentials
    185 Views, 6 Replies
    01-12-2013 03:50 AM
    I am having difficulty completing the dotted line construction on page 88 of Thom's book, the book starts by saying 'you can develop a sketch that includes a number of hole centres', how? This pattern is already in place on the downloaded file c3-14.ipt used in the exercise when you open it, then the instruction on page 89 in the book goes onto say 'This will help the Hole tool find them automatically' meaning some stages of the construction have been performed by the author and have not been explained in the book, I would like to know how to complete these stages. For a learner this is not easy to fathom out because the construction is on an inclined plane and because of the orientation of the hole pattern which is also rotated by 90 deg, can anyone help me please?
    Peter.
    Please use plain text.
    Re: Help completing model Thom Tremblay's book Inventor 2012 essentials
    01-12-2013 10:05 AM in reply to: Petervanh
    Attach your ipt file here.
    You can toggle normal lines to construction by selecting and then clicking the Construction icon in the upper right corner of the screen when in Sketch Environement.
    *Pro
    01-12-2013 10:59 AM in reply to: Petervanh
    ... and likewise, you can toggle points between sketch points and center points by using the Center Point toggle two icons to the right of the construction toggle.  This is what (I suspect) Mr. Tremblay is referring to.
    I routinely define hole locations by using construction geometry (rectangles, lines, etc.), then toggling the end points to centers.  I have that toggle assigned to the numberpad * key, and I use it frequently.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    New Member
    01-13-2013 08:14 AM in reply to: Petervanh
    Yes, Hole Centers are the key to the exercise. Thanks to those who offered assistance. Additional questions on that book can also be sent directly to inventor.essentials@yahoo.com.
    Active Member
    01-13-2013 01:29 PM in reply to: JDMather
    Thank you for your reply you have taught me something new, I think I will have to work through it my self, use the project geometry tool first and try to pick up useful points to produce construction lines as the book shown
    regards
    Peter.
    Active Member
    01-13-2013 01:34 PM in reply to: sbixler
    Thank you for your assistance, I think I will need to work through stage by stage first projecting geometry onto the face then picking up any useful geometry to place construction lines, a steep learning curve currently!
    regards
    Peter
    Active Member
    01-13-2013 01:47 PM in reply to: thom.tremblay
    Thom,
    Thank you for your reply and contact information, do you have or can you suggest where I can find more fully worked examples to follow? I think I need to work on a few more basic ipt's from first principles.
    Best regards
    Peter.
