• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Help With a Simulation
    130 Views, 3 Replies
    12-27-2009 12:32 PM
    I never worked with Inventor Simulation before and am having trouble running a simple Simulation. Hoping for some help from this group?
    I left a ZIP contains the necessary files for the simulation in "Customer Files" same subject "Help With a Simulation".
    I am tyring to determine the upward force imposed on the blue lift block by this mechanism when driven by a 63mm bore cylinder (20mm rod dia).
    It seems to be working but I don't know how to get the force I'm looking to the output graph?
    Any help would be greatly appreciated
    Rick
    Please use plain text.
    *Richard Chen \(Autodesk\)
    Re: Help With a Simulation
    01-03-2010 01:16 AM in reply to: rdonnellon
    Rick,
    Please upload your zip file here, so that we can take a look at it.
    -Richard
    Employee
    01-04-2010 11:52 AM in reply to: rdonnellon
    Hi Rick,
    Just in case it hasn't been noticed, Jimmy has posted a reply to the CF thread:
    http://discussion.autodesk.com/forums/thread.jspa?threadID=756875&tstart=0
    Thanks, -Hugh
    Hi Rick,
    You can calculate the value of upward force on lift block with "unknown force" functionality. Before invoking this command, please disable the imposed motion for cylindrical:2 joint and lock revolution degree of freedom for planar joint:9 since there are 2 degrees of freedom for this mechanism but "unknown force" only works under kinematic chains with one degree of mobility.
    Then you should specify the joint you want to dive to have a succession of static equilibriums and its final position, like the translational degree of freedom of cylindrical joint 2.
    If you still have problem to finish this, please feel free to let me know.
    -Jimmy Yuan
    *Please press the 'accept as solution' button if this thread answers your question, so others can quickly benefit*
    Hugh Henderson
    Simulation QA Engineer
    DLS (Simulation and Material Sciences)
    01-04-2010 09:36 PM in reply to: rdonnellon
    Rick,
    Sorry I didn't notice you have uploaded your models in "customer files"
    forum. In the future, please feel free to put the models and questions in
    one thread. They won't be missed :smileyhappy:
    -Richard
