• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Help Please - How to take away annoying lines from assembly parts?
    274 Views, 5 Replies
    03-04-2013 10:00 PM
    Hi Everyone
    I've just started using Inventor and am getting the hang of things, but one thing that really annoys me is these lines that are all over the parts I use in assembly. Screenshot attached.
    Could someone please help tell me how to remove them as it irritates me to no end.
    Thank you!
    Marco
    Please use plain text.
    Member
    Re: Help Please - How to take away annoying lines from assembly parts?
    03-04-2013 10:07 PM in reply to: marcopolo09190
    Go to individual part, select the sketch and OFF the visibility of those sketches.
    Distinguished Contributor
    Sereniance
    Betreff: Help Please - How to take away annoying lines from assembly parts?
    03-05-2013 12:05 AM in reply to: marcopolo09190
    On the other hand Inventor will turn visibility of the sketches off,
    as soon as you extrude them for example.
    Oh and you should put names to differ the parts as the model get´s more complex.
    - PhenomII1075t @3.6 Ghz- 8Gb - Radeon7970 -
    - Xeon 1230V2 @ stock Ghz- 16Gb - Quadro 2000 -
    - Factory Design Suite Premium 2013 -
    *Expert Elite*
    03-05-2013 04:36 AM in reply to: marcopolo09190
    And your sketches are not constrained.
    You sould pattern features rather than sketche entities in most cases.
    You might read this document.
    http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
    Inventor Professional 2014 Edu 64-bit
    03-05-2013 05:42 AM in reply to: marcopolo09190
    Those are sketch lines and/or projected geometry. You can turn them off by going into the appropriate parts and turning the visibility of the sketches off or by going to the assembly and the View tab then Object Visibility and turning off 2d sketches. Also if you are not extruding the circles, but just the squares around them you might change the circle lines to construction. Will make picking the extruded shape easier in the future. Also you could of used points to define the squares center instead of a circle and dimensioned to it.
    Steven White
    Lee C. Moore, Inc.
    www.lcm-wci.com
    Inventor 2011
    Intel Dual Xeon E31225 @ 3.1 GHz CPU
    16 GB RAM
    NVIDIA Quadro 600 GPU
    Windows 7 - 64 Bit
    BLHDrafting
    03-05-2013 06:09 PM in reply to: marcopolo09190
    When I'm in a rush and can't be bothered tracking down the part & sketch, I just hit F10. Toggles sketch visibility. Just a short term fix though. In the end you will have to track them down and deal with them.
    Other short cuts are CTRL+] for origin workplanes, CTRL+. for Origin point and CTRL +/ for Origin axes. Substitute ALT for CTROl for user planes, points nad axes.
    Brendan Henderson
    Web www.blh.com.au
    Twitter @BLHDrafting
    Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
    ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
    Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
