• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    desilva2010
    Help - How to hide dimensions in sketches
    255 Views, 3 Replies
    08-20-2012 06:15 AM
    I'm working with a series of 3D sketches. Some sketches must remain visible as reference. While creating the sketches, the dimension call-outs grow too distracting from the linear sketches. Is it possible to hide, or toggle off/on the dimensions while leaving the sketch geometry visible?
    Please use plain text.
    Distinguished Mentor
    ampster
    Re: Help - How to hide dimensions in sketches
    08-20-2012 06:27 AM in reply to: desilva2010
    right click on the sketch in the browser and choose hide dimensions.
    Valued Contributor
    desilva2010
    08-20-2012 06:50 AM in reply to: ampster
    Aha, that was the option I was searching for.
    1. Right click the sketch in the feature manager
    2. Select Dimension Visiblity
    I'm curious if I can create a short-cut key to toggle the dimension on/off? Is it possible to create a custom keyboard key?
    *Pro
    jletcher
    08-20-2012 07:01 AM in reply to: desilva2010
    I am sure you can find or make a macro to do this this way it does it to all sketches.
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
