• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Having trouble using ipart in assembly
    134 Views, 2 Replies
    11-15-2012 08:38 PM
    I created a inventor part by name "011-03-054-A-25x50 HS" 100mm in length. Used "011-03-054-A-25x50 HS" in a assembly and used the same part in another assembly. Then I created a ipart  with a different length which is 250mm. Now I want to use 250mm length in the second assembly. How do I doit? I couldn't find an answer any where. I am using Autodesk Inventor 2013 in windows 7.
    This was called configrations in Solidworks and was ver easy to use. can anyone help?
    Cheers,
    Viv
    Please use plain text.
    Valued Contributor
    Re: Having trouble using ipart in assembly
    11-16-2012 12:09 AM in reply to: viv3k
    From the photo it looks like the iPart parent file is inerted in the assembly. Usually that happens when a part is "converted" to an iPart after being inserted into an assembly as a plain part. To "fix" this, first, make sure the iPart parent file is set up correctly with the proper keys, filenames, etc. then generate members from within the iPart. Now go back to the assembly and use component replace and replace the iPart parent file with the proper member that you just generated.
    Mike
    New Member
    Re:%20Having%20trouble%20using%20ipart%20in%20assembly
    11-20-2012 09:01 PM in reply to: mikebelter
    Thanks Mike.
