• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: Hatch not showing when converting to DWG. Strange problem. Inventor 2013
    12-06-2012 10:14 AM in reply to: orchjam
    Hi Guys.  Well I've installed service pack 1.1 on his machine.  That didn't work.  It's still not writing the DWG file correctly.  Starting to think this may be a bug. But I'm able to do this with my profile so. PLEASE PLEASE help.  This is going to give me a heart attack.
    Many thanks.
    Please use plain text.
    Product Support
    innovatenate
    12-06-2012 10:30 AM in reply to: orchjam
    Have you tried re-installing DWG TrueView? Re-installing DWG TrueView is failry painless. It is definetly worth a shot in this scenario.
    You may want to try a repair solution for a corrupt window's profile in Inventor just for good measure. I've added  step 6-8 as a precaution. Please make sure that step 1 is followed. Note that the following solution will delete the application settings. You may want to 'Export' the application options so that they can be reloaded after the solution.
    To fix a corrupt profile
    1. Close all Autodesk and other open applications. Disable anti-virus, and lower UAC (User Account Control in Windows) to 'never notify.'
    2. Go to Start > Run > type " regedit" to bring up the registry editor
    3. Browse to "HKEY_CURRENT_USER\Software\Autodesk\Inventor
    4. Export the the applicable registry version key for a back up
    5. Delete the applicable registry version key/hive (note Inventor 2013 is version 17, Inventor 2012 is version 16, etc...)
    6. Go to Start > command prompt > launch the program by right clicking and selecting Run As Administrator
    7. In the command prompt change the active directory (using command 'cd') to C:\program files\Autodesk\Inventor 20XX\bin)
    8. Type 'apprenticeregsvr.exe/install' *note: This step shouldn't be necessary but will not hurt anything .
    9. Launch Inventor and re-test the issue.
    Give this a try and let me know if this helps to resolve your issue.
    Nathan Chandler
    Product Support Specialist
    Product Support Americas
    Autodesk, Inc.
