• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Accepted Solution
    Hatch not showing when converting to DWG. Strange problem. Inventor 2013
    296 Views, 11 Replies
    11-28-2012 08:28 AM
    Hello.  I'm having lots of trouble converting from Inventor to AutoCAD DWG.  Here is the situation.
    I installed a brand new install of 2013 Product Design Suite Premium on a new machine.  When I go to run Inventor everything seems to work fine.  I make a drawing of a part and export to DWG.  That's a requirement here.  When I go to open the file in AutoCAD, the hatch pattern doesn't show and it looks like the boundaries for the hatch move to 0,0,0.  Very stange and I haven't been able to figure this out.  I installed Premium on another machine and performed the same export.  Works fine on the other machine.  The other machine however,  has 2012 installed as well. Could this simply be a bad install?  Please help.  Really confused about this one.
    Many thanks.
    Jim O
    Baker Hughes.
    Please use plain text.
    Product Support
    innovatenate
    Re: Hatch not showing when converting to DWG. Strange problem. Inventor 2013
    11-28-2012 03:57 PM in reply to: orchjam
    Which export/save as options are you using? Have tried modifying any of options that you are currently using? It could be that the settings you were using have been reset...
    Nathan Chandler
    Product Support Specialist
    Product Support Americas
    Autodesk, Inc.
    11-28-2012 04:00 PM in reply to: innovatenate
    Hi.  Yes.  I modified the option for the proper ini file and the proper template file.  Doesn't seem to make a difference.
    Product Support
    innovatenate
    11-28-2012 04:11 PM in reply to: orchjam
    On the other machine, are you logged in with the same user profile? You may try running DWG TrueView 'As Administrator' once on the machine.
    Nathan Chandler
    Autodesk, Inc.
    Valued Mentor
    11-28-2012 04:31 PM in reply to: orchjam
    I'm probably wrong but, Inventor drawings usually have a tan background and AutoCAD, it seems to me, usually has a black or other dark background. Black lines on the Inventor tan background automatically become white on AutoCAD's dark background. But Inventor doesn't like black, it has this purple color that is often a default, and seems to find an excuse to change things to it if you are not careful. Your hatching may look black in Inventor, but actually be a purple that you can't see in AutoCAD.
    Now, I don't know about the boundaries moving so that makes me think I'm probably wrong but I just wanted to take an opportunity to rant about colors. I used to have some sort of viewer where I could open AutoCAD drawings as all black, last time I tried to look at a vendor or customer drawing all the text was yellow, but the viewer (what is it? True View or something like that)  has a white background - very good, thank you oh so very much, really.
    12-03-2012 10:31 AM in reply to: innovatenate
    Thanks for the reply.  That didn't seem to do it.  Is this starting to look like an install issue?  Is there a system variable I can mess around with?  This is very perplexing.  I don't know where to go from here.
    *Pro
    jletcher
    12-03-2012 10:58 AM in reply to: orchjam
    Use Autocad to put in new hatch this gets the drawing done. As far as a fix have you installed all hotfixes and patches?
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    12-03-2012 01:50 PM in reply to: jletcher
    Hi Jletcher.  I don't think that service patches are the issue because we installed the same version on the other machine and it works fine.
    12-03-2012 03:36 PM in reply to: orchjam
    Ok Guys.  I think I got it.  It seems to be the permissions. I logged on as myself on the machine in question and it worked.  Can you guys tell me why? I am however running an iLogic routine to automate the process of converting the drawing.  Maybe that's it?
    12-06-2012 10:13 AM in reply to: orchjam
    Hi Guys.  Well I've installed service pack 1.1 on his machine.  That didn't work.  It's still not writing the DWG file correctly.  Starting to think this may be a bug. But I'm able to do this with my profile so. PLEASE PLEASE help.  This is going to ive me a heart attack.
    Many thanks.
